- 27 Mar 2004
- Telford
edit
I'm hoping this is the best place for a strange situation i've found myself in:
I upgraded the firmware of my hikvision nvr and now when I try to access it remotely from a web browser I get the message 'network unstable' and cannot login.
Anyone know of a work-around?
Hik vision cameras and nvrs are regional. And suppliers are buying Chinese region and overwriting the firmware with UK language versions of non official firmware.
Cutting a long story short you're best not attempting to upgrade the firmware unless you purchased from an official source. As it'll probably brick your hik
Ok I'm sold on Hikvision but where to buy from?
They're pretty good.. Very easy to configure, as it just registers the mac address on the samsung smart cam site. No networking knowledge needed. Plug and play. Ethernet or Wifi. You can even leave uPnP off on your router, and no port forwarding needed... No need for a DVR either as the SD card does a fantastic job at recording movement. Night vision is also excellent.... Not POE, so you need to power with the power adapter.
I have two in my garage, which are sprayed matte black and you'd not know were there, unless you were looking for them.
Don't think the samsung tablet of tv makes any difference tbh. I just use a browser or an iOS device to view / playback.
Hi guys,
Looking for a IR CCTV solution for outdoors to monitor my driveway. It needs to be relatively wide (4mm) and it is a double length drive way. Based on this thread I believe I need an NVR with EXIR 3MP camera.
People seem to suggest:
Hikivision DS-2CD2232-I5 (£65 from China)
Hikivision DS-7604NI-E1-4P (£165 from UK)
1TB HDD (£70 from OcUK)
Does this sound about right? Can the solution be done cheaper? How long would you expect it to take a professional to fit into a new build?
Cheers!
I've just picked up and installed two HIKVISION's DS-2CD2132F's ($95 each from China) overlooking my driveway, and two Samsung Smart Cams (don't know the model numbers) but accessable via Samsungs SmartCam website or iOS app. They cost me $120 ea
I have SD cards in all of them, which records when it detects motion. Also I created a gmail account, and have my two HIKVISIONS's send 3 pics at 2s intervals, whenever a line is crossed over my driveway.
Can't wait to catch who's been pooing in my mailbox !!!!!!!!!
.Make sure your cameras from China have English menus peeps.
For NVR at the moment nothing beats Samsung SRN-472S. Proper "end consumer ready" finished firmware, ONVIF, built in POE, just over £120 without drive.
On their site it seems to have been replaced by the SRN-473S?
As above, I don't think you need an NVR unless you're keen to record a lot of video. I'm looking to set up a system myself and I'll be using the same Hikvision cameras as you but record to SD card and send pictures to an email as thedoc46 suggested above.
