Uninstalled iMVS run CCleaner then installed it on backup PC - still no joy - I am missing the plug in.
Might have had a hit last night.
Was sitting here at 10.30 and saw this white transit slowly drive down road - 2 min later it did same up road - then it came back down road- Got my bright LED torch out and lit them up through window.- they stopped and drove up my drive- Driver came to door so shouted through go to window - Opened top light to talk to him and he wanted no 19 - said this side goes up to 9 and other side to 8 - What's name of people you want - (forgot he said have some kiddies play stuff to deliver) Have you got a name - can't remember - Whats name of road - this one he said - Bye bye
Dialed 101 and gave them reg number and description. Got a perfect shot of him at front door on cam.
Perhaps some one is having a kiddies party today and he was delivering the play things but 10.45pm is pushing it.
For the iVMS-4200 Client you do not need a plug in, IIRC. The plugin is for your browser to work when accessing the cameras via FF or IE etc. If you typed in the IP address of one of your cameras via a browser it will warn you that you do not have the right plugin and even offer to install it for you. Failing that you can download the latest plugin from Hikvision for your browser.
The iVMS-4200 Client just installs and then you add the NVR as a device and the cameras attached to it will be available.
Good result with the grabs.
When our car was broken into the two scrotes were captured on CCTV and that evidence helped to convict them.
