I can't see any. I'll ask one of our installers or Hik if I get a chanceAhh OK yeah I was comparing to the DS-2CD2135FWD-I I you mentioned.
Where exactly are the emitters on the DS-2CD2135FWD-I I? In some (most) photos of the camera itself, it simply looks like there are no visible IR emitters which is strange?
My dad is looking to upgrade an existing analogue 4 camera system, it's only SD and the interface is very clunky, to get the video from it I need to use an older laptop with internet explorer in compatibility mode, this isn't good going forward, most of the computers in the house are on Win 10 now.
I've done a lot of reading, Hikvision and Dahua seem to be recommended a lot. We would probably go for an 8ch NVR and add a 5th camera. But I have no idea which NVR to get and which cameras, or what resolution. I have read that turret cameras are usually recommended. I also read about buying from UK dealers, though it seems that some here haven't had a problem buying from Aliexpress.
Any suggestions would be great. Thanks
I would probably now advise against trying to get Hikvision as most dealers are not supposed to sell to public. I can still get my hands on them mind, but I worry that it will get to the point that you look to upgrade or replace the odd camera and getting hold of them would be difficult.
I've seen a few Dahua setups and I'd say they're equally as good as Hikvision.
Lens size and mp depend entirely on where you want them mounted, field/angle of view etc. So it may be worth trying to find out the spec of the current cameras to give something to compare to.
Dahua are great, knowledgable staff too - I spoke to one of their sales guys the other day in regards to a WiFi camera (Hik are 10 week lead times, ridiculous).
It's worth noting that Hik NVRs are ONVIF compliant, therefore any ONVIF camera will work, you may lose some features such as line crossing detection and number plate recognition but not that many people care.
