Ooops... Hik-Connect not HiDDNS.Thanks
So you do not recommend hikconnect?
When you say all ports, I assume you mean all the ones on the server?? And do not need to do anything with the camera ports?
Just the server ports
Cool thanksOoops... Hik-Connect not HiDDNS.
Just the server ports![]()
Hik-Connect uses UPnP to automatically forward the portsCool thanks
I thought hikconnect meant there was no need for forwarding but to be honest I have not read into it yet
Will check it out later on
Hik-Connect uses UPnP to automatically forward the ports![]()
Thanks guysHik-Connect is Hikvisions cloud service. Works well on those 4G installations which I have to deal with now and again.
Thanks guys
I can confirm I have just forwarded only the server port and all seems to be working perfectly. No Hik-Connect.
HTTP port is pretty obvious... I imagine RTSP port is tied into that HTTP/browser viewing as the Android client seems to be working perfectly remotely with just the server port forwarded.
Will update though if I do find a particular feature not working![]()
Ahhh OK fair enough! Makes senseThink you’ll be okay on the mobile app (for now) but some desktop viewing software likes to access the HTTP stream.
If that Swann kit doesn’t use IP camera’s, then ditch it. No new installs should be using non IP camera’s. I don’t care how good TVI etc is, anyone installing a new install needs to be using IP cameras. They need a kick in the ass if they do.I'm new the this section, and after advice. I would like to set up a CCTV system at home. I have seen a kit from maplins , Swann 1080p 8 Channel 1TB DVR and 4 Heat-Sensing Camera CCTV Kit, firstly is it any good?
Can anyone recommend a different route? Ideally at the moment I don't want to spend much more than £300 on the whole system, will only need 2 cams at first but want to be able to expand in the future.
Any help will be much appreciated
GM
TBH, Dahua or Hikvision and if you can’t stretch your budget then you won’t be installing a decent setup if you want to include a decent NVR with good storage.
Better holding out and saving more to your budget than buying that Swann system.
Not quite... @Scream is probably referring to the more professional range that I recently bought...so something like this then? http://www.cctvkits.co.uk/hiwatch-by-hikvision-1-4-camera-4mp-ip-cctv-camera-kit-builder.html
Means its recordingI will look in the manual but somebody here likely knows
What is the showreel style symbol for on each cam when viewing hikvision directly from the nvr monitor?
Ahh simples.. ThanksMeans its recording![]()
Not done it with Hik, I know some CCTV systems integrate with the likes of home control software. We tend to just use HDMI over Cat6 and do it that way to the TV.Anyone know how to get the Hikvision ivms-4500 app displayed on a LG smart TV or is it not possible ?
That would be sensibleAhh simples.. Thanks
Assumed they'd just use a red circle like everyone else lol
