3260 posts about torches lol
The VG10 has three brightness settings + strobe but if I select any setting other than low, the beam goes brighter (not full brightness) then flashes (signalling low battery) and remains on low brightness level.
Isn't the driver included in the switch? My VG20 came with a spare if you want to try it?
Guest2 - I have the same charger, great but of kit! How do you think that tk75 compares to my Skyray king for real world usage?
How about here , although probably more expensive than you paid?Fenix TK 75 L2........
Not yet available in UK (that I can find)
Yep, the spill is massive on that King.
I bet it lights up everything when in open space at night
I have a couple of Fenix torches that use CR123 batteries but I notice that they can also use 18650 Li-ion batteries. Can anyone recommend some good batteries to me please? I take it the Intellicharge i4 charging unit is a good one?
I acutally used it the other night to light up my whole garage when the bulb died late at night and I didnt have a replacement to hand!
I stopped because I seemed to have attracted the attention of a helicopter!
That beam looks similar to my micro Sun, the TN31
