Any suggestions for a good quality compact AA LED torch please?
I have one of the cheaper CREE metal ones from Amazon but want something a bit better quality.
See 3 posts up
See 3 posts up
If you could stretch to a bit more I would recommend the Zebralight SC5 http://www.flashaholics.co.uk/products/zebralight-sc5.html
I have the SC5w and its just easier that torches are smaller and run of AA batteries that are easily available almost anywhere. I have owned quite a few larger expensive torches and sold them all because they are not much use if they are big, heavy and run on batteries that you always need to charge - sure you need to charge AAs but its better knowing they are in remotes and all sorts of other stuff around the house
The SC5 also has a great user interface even if its a bit confusing at first
That will likely replace my BLF, similar size, but with more power. LUMINTOP Prince Copper (https://goo.gl/UIqRfY) - Coupon: LPE11 Price: $31.59 (regular price:$78.90) Over 50% OFF
Lumintop Tool Keychain Flashlight (https://goo.gl/QTYw2D) -Coupon: LKF11 Price: $9.59 (regular price:$19.90)
Lumintop TD16 (https://goo.gl/hjRciz) - Coupon: TD16GB Price: $36.99 (regular price:$71.01)
Opus BT-C3100 V2.2 Charger (https://goo.gl/yAlr94) - Coupon: OPUSD Price: $29.99
Jetbeam JET-u AAA Flashlight (https://goo.gl/AHnTyf) --Price: $8.99 with Coupon: JETμEN (The price is only for your 1st piece)
Limited Pieces for above discount price! Please take of it, thank you!
Xiaomi Yeelight Smart Light Strip (https://goo.gl/srJjr1) --Price: $36.99 with Coupon: XMstrip
Promo for Outdoor Packs! (https://goo.gl/zSG8Ms)
ZanFlare F1 Flashlight Promotion (https://goo.gl/dl88XI)
I have two variants of the skyray king. Both are very reliable and throw a lot of light for the price
Where did you purchase? Seen a lot of places with reviews saying LEDS died.
Looking for a Torch for dog walking. Budget of upto £50, any suggestions?
Currently using a LE Adjustable Focus LED £7 rainforest one, and looking to upgrade this.
Comparing to listed modes on a Fenix all 3 LED together is about 400lm which for 13 quid all in is great? not fallen apart yet though Ive not used it roughly, the batteries are about half the capacity listed but arent terribleThree 5000 lumen LED lights
