My Astrolux EA01S tends to keep me visible.Hopefully cars will see me even better, I've been using the Blackburn 700 for years but this is twice as bright.
My Astrolux EA01S tends to keep me visible.![]()
I don't have it on at max brightness all the time, unless I'm using a cycle path away from the roads.11,000 lumens, it's a wonder you don't blind everybody
I got many car horns with my 700.
I was surprised how long my torch lasted, but I suppose the airflow helps cool it. At this time of the year, it's probably the battery that gives up before the torch overheats.Doubt that the Astrolux EA01S can last on 11,000 lumen for too long. Surely that torch will get a bit roasty.
will they attach/detach from handlebars easily, for shopping .. do you need a spare bracket for another bike like my aging cateye ?Hopefully cars will see me even better, I've been using the Blackburn 700 for years but this is twice as bright.
test environment for adaptive - I'm going to get a bigger bike light , and, in car, approach more with main beams, if that's what triggers them
So almost useless then, unless you want to blind and burn someone then lol. Still pretty impressive for the sizein reviews it says 30 seconds max and then needs 10 minutes to cool down before you can use it again at that brightness
Is there an equivalent or better torch that lasts longer?So almost useless then, unless you want to blind and burn someone then lol. Still pretty impressive for the size
not for the size that I know of from the top of my head. Something like a Marauder Mini can do 7000 lumens or the Marauder 2 can do 14000 lumens for 5 mins or a decent 3200 for at least a couple of hours.Is there an equivalent or better torch that lasts longer?
Hi all, I have an old magite. It is 49.5 cm long. Can anyone identify the model for me please? It has a standard bulb. Can I upgrade this at all?
