Spec me an LED Torch
I got my Xtar charger today. Can anyone tell me what position I need the switch in to charge 18650 cells? Am I ok to charge 1 on its own?
Thanks
Cheers.
Just read a review, as both channels are independent I assume I can also charge 2 different cells at the same time.
I'll just use the slow charge for now. May also use it to charge my iPhone tonight :D
Can you guys recommend me a Small to medium size torch up to say 8" with a good range on it? it will be for night shifts doing security so needs to be bright with good range. unto £60? all inc batteries etc
How long should they take to charge? Been 3 hours now and they aren't warm. I'm going out soon so will take them off.
Li-Ion cells don't get warm unless they're being charged fairly fast. if you're using the 500mA setting they'll take a good five or six hours to charge depending on capacity and probably won't rise perceptibly above room temperature :)
I'm off to bed, I'll let you guys Help Stinky out :)
As above, BC40 :p
It is the perfect guard's torch, it can also double as a baton :p
And it's got range!
They are actually posted on page 13 when I posted initial BC40 thoughts but thanks!Can't wait to get the smooth reflector on it!
Smooth gives more range, way more range!
They have not confirmed a price yet, still waiting.
bc40 beam shots
country lane unlit
bc40 130lumen eco-mode 11hours runtime
bc40 830lumen high-mode 1.5 hours runtime :)
great work torch. sturdy yet light in use, tucks under arm easy during tasks, impact resistant to 1.5m, waterproof to 2m and scratchproof mineral lens
thanks guys.
i have ordered :D will have a backup for work now to ;) dam u ocuk lol
ThriceNightly - i couldn't find your email address so i didn't put you down as the referral sorry buddy :( (not sure what that would have given you?)
all done thanks guys. not sure how but i managed to order 2 sets of batteries :/ came to $110 ish all in, slightly more than i wanted but im going on you guys lol
