- 7 Aug 2004
Also is there a way to limit GPU folding to say 80% of each GPU ? I tried this in the setup --> heat control section but it didnt seem to do anything ?
hi..follow what to do here
http://forums.overclockers.co.uk/showpost.php?p=24788107&postcount=56
also I would use the f@h client instead of tracker
make sure the " client-type" " advanced " are done, your 2 gpus will get you over 100'000 PPD.![]()
Hi followed the guide, thank you
Have added client type advanced to GPU 0 and 1 and cpu.
CPU is running fine, however the GPU's just say paused waiting for idle? How do I make them start going?
Also is there a way of limiting their use ? I really want them to run at 80% load so its not so loud and hot.
they will use 99% gpu power, you could just run the 680 for now and then run both when not at the pc so heat/noise doesn't bother you?Just set it to full and its now running the GPU's, yes confirmed it is running 0x17 on the gpu unit and the 0xa4 on cpu.
Hmm thats a bother, really want it to run at 80%, any idea if someone will sort this out somehow ?
670 - 80k, 570 - 30k, cpu - 11kaww total has now dropped to 121000670 - 80k, 570 - 30k, cpu - 11k
. turning your pc at night is fine , its up to you when you fold
Haha maybe, but the 570 runs WAYYYY to hot for my liking in the server as its tucked away in the loft! :/ Am hunting around for the best price/power/heat performing card![]()
Yeah was looking at this:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-220-EA&groupid=701&catid=1914&subcat=2392
When I get spare cash, ill wack her in!
I *MIGHT* have to put this on a PCI-E extension cable ribbon, possibly 4x PCI-E to 16X slot, will that effect it or is PCI-E bandwidth not a problem with folding?
