They can't?
Yeah, makes me question spending £50 per session on coaches that don't use an underwater GoPro as part of their analysis!
I'm going for a wetsuit swim on Monday so I'll see how I do then.
They can't?
I bet you don't need neoprene shorts though!![]()
That looks as I expected, you're pushing the water down until you are halfway through the stroke and then starting to push it up at the end of the stroke from what I can see, which would account for your sinking legs and lack of pace.
Some dude told me that using the sauna/steamroom and jumping back in the pool for the cold shock is 'good for the immune system'. Can anyone verify that?
I did a wetsuit swim today, first one since last summer!
It's amazing the difference it makes. I was considerably faster wearing the suit but I was also more exhausted, having to take rests after each length. I guess the suit improves my body position but my stroke is still inefficient.
That's a massive jump in av pace, you knocked a minute off!!!Good job!!
I'm guessing the suit is keeping you body / legs up more and streamlining in water
Went to the pool today to recover from a marathon on Sunday. 10x breast and then 10x front crawl warm up and I then it thought I would rest my sore legs by using one of those floats that goes between your thighs. night and day different.
Breathing was dramatically more comfortable, I could happily skip breaths even while bilateral breathing, I barely raised my heart rate, I swam faster and didn't tie. i don;t even know how much faster because my Garmin swim was utterly useless and I kept loosing count, I think in 2 sets i did 12 lengths instead of 10 it felt so easy.
Considering how trashed my body is post-marathon (I have to scoot down the stairs on my bum) I did a quick 2200yd in 58 minutes taking it easy, which would be 2nd fastest swim.
So I think I'm like Shamrock, hips are dropping dragging me down and making me exhausted.
ok, I will have to see if there is an option to try out swimtag and see if it works for me.
As you suggest I had not realised it is giving wall clock times for each turn so you can spot missing turns - I apply negligible effort to pushing off, the deceleration on arriving at the end is greater than push off - it seems that reliable gps based solutions working inside buildings does not exist, I had long time considered one of these sportcounts but thought it might be too inconvenient.
