I'm about to start my first ever build from scratch (its coming within the hour!)..
I have a question, how do would you recommend setting it out when using a new case? Obviously its easier with the case on its side.. so would you put it straight onto a table? I wouldn't want to scratch or damage the table or the shiny new case..
Is it okay to lay it on a towel or something?
Thanks
David
Thanks
David
 ), so I'll hopefully be starting it the following few days.
