indeedFor example - @tamzzy has clocked his 3200MHz sticks to 3733MHz C16 with minimum effort - on a Zen-2 build.
It seems to be the general consensus of members upgrading from what they regarded as systems that were adequate/managing (even FPS) - but as soon as they made the bump up, noticeable difference in performance and a 'smoothness' they can't explain from data alone.@Plec so i've been playing CSL with 530k pop with my 16gb of single channel memory...
it appears that i was semi-wrong. definitely was the 3770k choking with so many instances...even with 16gb single channel memory, the game is so much smoother with the 3700x than it was with the 3770k.
granted it isn't as smooth as 3700x with 32gb ram though...lol
indeed. budget dependent. but for a budget of £1500, more than enough room to accomodate itGuess its all down to your pocket.
indeed. budget dependent. but for a budget of £1500, more than enough room to accomodate it![]()
#indiantakeawayI'm also hungry.![]()
#indiantakeaway
full tilt. it's already considered silent for me lol.will you be setting up a curve once fully up and running and assuming temps allow? Or will you run at full tilt regardless?
No worries - if i were to venture down the yellow brick road i'd research. I would be interested in low RPM (curve kick in at 70 degrees) when using word/excel/browsing on a minimum of a couple of screens.full tilt. it's already considered silent for me lol.
so i don't know how useful it will be to you, even if i make a curve :/
@orbitalwalsh @Plec
new 3 slot mini itx case: Lian Li PC-TU150
http://www.lian-li.com/pc-tu150/
granted it's ~double the volume of the rvz03
But from a token glance if you remove the squatter standing at edge you'll have more room for your furniture in your new house design.going to be tight boys and girls ...
*@orbitalwalsh - busy will look properly later:
But from a token glance if you remove the squatter standing at edge you'll have more room for your furniture in your new house design.![]()
OK, possible build names: Heath Robinson on Crack, Square Peg - Round Hole or Mary Shelly's Love Child.@tamzzy @Plec
CAD is playing up and quick dash on Google sketch in minecraft form
need to cut the front as cables come out by 12mm
tight
60mm thick AORUS should work- with slight gap and just enough clearence from PCIe slots
up top, TD02 240 slim rad and slim 15mm fans - and yes- they make ARGB Slim line to
think i'll have to move the rad along more to front of te case and ports would be on the side of I/O shield
