- 1 Dec 2015
^^^ any more incite @orbitalwalsh - have you had time to apply it to CAD?
GPU is flipped, so fans facing upwards . Think standard ATX case with inverted GPU .
3D print fascia may be required to give a little extra room for cables.
Most likely a plexi glass panel would be cut to mount 240 CLC and intake for GPU
