mortals said:I got FSAA working finally
I installed the Catalyst 7.2 drivers, I found out that the ones that caused me problems before were the 7.1's and CCC. So I'm now on the 7.2's with no CCC installed![]()
Just noticed your 3dmark06 score...how did i get almost 900 points more when we have the same gfx card, same amount of ram, but you have a much, much faster cpu?ajgoodfellow said:Ahh - cool! Glad you got it working!![]()
ajgoodfellow said:Not sure - maybe you had better drivers?![]()
niteflite01 said:I wish the challenges were closer together, as in not so much of a long drive between some of them. And I wish there was some indication as to whether you'd done one before or not, as it's easy to re-do previous challenges.
ajgoodfellow said:There's a tick above previous taxi missions (hitchhiker/model) and a cup if you've done a previous race
not done many races or anything.
I made an adapter for my old xbox pad and downloaded the XBCD drivers and the rumblepack adds to it.
loving it all
Spunj99 said:According to a few posts on the forums theres problems with using GameSpy ID's that you used for the beta(s). Going to create a new ID and try again i guess.
Glad to see they put those 3 extra weeks to good use fixing bugs.
EDIT: That didnt work at all.![]()
ramdor said:If you used the beta, ensure that the key file in Documents and Settings\All Users\Application Data\Test Drive Unlimited contains the same key as your retail. I think the file is called CDKey.txt or something.
Richie.
