I read that image to mean that when you first install the ram the voltage should be set lower than 1.65v.
But that makes no sense. Whats the point of that? How can you set the voltage without putting RAM in the first place?
Presumably when changing from one setup to another?
can anyone explain why http://www.overclockers.co.uk/showp...ue Edition 1866C8 (6x1GB) Triple Channel DDR3
is 493 £ when u can buy the same ram http://www.overclockers.co.uk/showp...n 1866C8 (2x1GB) Dual Channel DDR3 (CS3222770)
3 times and pay 458 £ ? i always though if you buy in bigger bulks u get it cheaper ? ocuk think in different way?
so im confused if i buy http://www.overclockers.co.uk/showp...GB) CAS7 Dual Channel Kit (F3-12800CL7D-4GBHZ) this ram it will damage cpu as it uses 1.9v?
so basically u will need to underclock your memory and timings to not damage i7 cpu what the heck ?
Something has gone very wrong here, When setting VDIMM voltage it has ZERO affect on the CPU or the onboard memory controller, All it does it set the voltage that supplys the RAM, The ES sample i have used works like this and i would expect all other board to be pretty much the same, Maybe ASUS has dont something rather strange with there board, The intel board i have used DOES NOT HAVE THIS ISSUE.
