Hi Psycho
I want as simple solution as possible, I'm not to bothered about mic.
For instance although over my budget I was looking at Sennheiser RS180 wireless headphones as this will work through my denon avr x2000 which I run all my devices through.
What do you think?
They are good but your paying a lot for the functionality rather than sound quality. e.g. The RS180 is probably comparable to HD558's or something like that (which I own, but only cost me around £80 brand new and can be modded into HD598's for free).
That AVR should have a decent DAC and AMP within it to power headphones, if you don't care about having a mic then get the best pair of headphones for your budget.
Q701 IMO would be the best for competitive gaming. A modded Q701 (bass port mod) for all rounders.
If you want to see reviews of the best wireless headphones look here
http://www.innerfidelity.com/content/innerfidelitys-wall-fame-wireless
He seems to like them but a lot of people don't rate a lot of what he says. Head fi should have a lot of info on wireless headphones too but ultimately wired > wireless and costs less too to achieve the same sound quality. Spend the same amount on wired as you would on wireless and generally you end up with better quality.
I see the appeal of wireless though and that is why I bought the wireless mixamp over wired versions. I cannot have a wire trailing across the room where it can get snagged or ripped out by someone damaging equipment.
http://www.astrogaming.co.uk/a50
wireless headsets (which are decent quality) like the above IMO are overpriced too, which is why I opted for the 5.8 mixamp for £60-£80 (which is now very rare and hard to find as it's in very high demand and been EOL for several years now) and a set of decent headphones like the Q701 which only cost me £120 brand new from America (£200-£300 here in the UK with a RRP of £400) but I waited to buy them and I upgraded several times.
I spent <£30 on my first set of decent headphones brand new Panasonic HTF600 then HD595 £75 second hand, then HD558 £80 brand new then Q701 £120 brand new.
The Q701 is end game in terms of competitive gaming and sound quality for the money I will never find a better headphone than that. To beat it you need to spend around £300 or more for minimal improvements, the £95 deal from America was a steal and quite a large number of forum members in sound city bought it, in fact there are 2 HUGE threads in sound city about that particular headphone thanks to me.
If you really want wireless then RS180 (headphones only) or a 5.8 mixamp (headphones + mic) are your best bet tbh. If you can get away with wired, grab yourself a set of Q701's for similar money (a guy is selling his in members market for cheap, second hand ones though) and plug them straight into the AVR.
