- 17 Jul 2006
BillytheImpaler said:What memory test? The POST?
Yes. Please don't tell me the worst.
GoldenGlory said:Well it reads the memory and then when it would normall read the HDDs it stops. Looks like its crashed as the FAN RPMs arent moving. help?
rmuir said:just gotta dirty look from 'her indoors' cause im laughing so hard @ this thread
Raikiri said:Either the HD is dead or the windows installation has been corrupted - try and format again.
Swedish goat snuff films, probably.salami1212 said:i bet it aint porn.. bet its like illegal stuff![]()
maranello168 said:link me to your auction, i'ma buy it and see what you're trying to hide, muahahahahahhaha![]()
GoldenGlory said:Right, I've tried deleting the porn etc in windows. It deletes it, but if I refresh the folder it re-appears. Something isn't right there.
Scythe said:Ok, this might work. Go http://gparted.sourceforge.net/livecd.php and download the correct iso for your system. Set your BIOS to boot from CD and reboot with the iso correctly burnt (with nero or iso burning program). When it boots up you will be at a prompt saying "blah blah" but the important bit is where it says boot:
at this stage just press enter. When the GUI kicks in, find the correct drive and delete the partition and reformat as FAT32 or something, then delete the partition again. Reboot and check the HD![]()
