What board do you test with Gibbo ?
Maximus IV Extreme.
you're above your own recommend max voltages (1.38v) there![]()
Crikey how are you managing such low temps with that sort of voltage?
I'm kind of a noob when it comes to overclocking (which is one of the reasons i joined here, to get some more knowledge on the topic), but liquid cooling, whats the highest clock speed? I read somewhere that origin had pushed it beyond 5 ghz, but i think they were air cooling.. Any ideas as to what speeds are achievable with liquid cooling?
If your on extreme cooling or very very good water cooling some would say you can get away with higher voltages.![]()
Gibbo - what is 1.45v lifespan are ? 1 year / 5 years or 10 years ? Mine is 1.48v for nearly 4 months now and I want to know how long lifespan on my cpu got left ?
According to Intel upto 1.425v will not effect lifespan.
Thats official word from Intel, I'd imagine they are quite conservative, as such I'd imagine 1.45v will not limit lifespan either.
1.48v however is unknown, if may not limit the CPU's lifespan at all, especially if its kept reasonably well cooled.![]()
What would you use 5.4 ghz for though other thn bragging rights ?
I'm pretty sure most games would run pretty well with the stock
3.5 ghz, so unless you use heavy duty program's daily, whts the point
Of over clocking the cpu this much??
I need it for MS flight simulator X
100% usage at 4Ghz here at the moment so if I can buy a pre OC 5GHz I will press the buy button if it's not a ripoff price.
Maximus IV Extreme.
Good luck Boostjunky - are you purchase the whole new 2700K or upgrade from 2600K ?
100% ?! Jeez! I used to play FSX on a c2d ! I still use a c2d for gaming!
But then that's just me![]()
