Probably not worth it if you rely on the computer for work and need 100% guaranteed stability.what sort of overclock could I expect to get on this (if it's even worth doing it thesedays!).
In general would be looking at 5.6/5.7ghz p-core but this will come at a heavy power penalty (~320w).
Correct, top. Easy. Big case (specced as you are used to the phantom enthusiast - normally I would've suggested a smaller case)Also for mounting the cooler, would this ideally go on the top? how easy is it?
Case will have 4 fans - 3 front, 1 rear. That's all you need (+ 3 fans from the aio)also would I need anymore fans anywhere
All from the motherboard. Aio pump goes to aio header. 3x aio fans have daisy chains in-built and goes to the CPU fan header.how hard is it to control them?
Mobo has 6x case fan headers - you will only need 4. So plenty to go around.
Someone will always be around to helpIt's good to know if I got stuck with the build I can jump on here and get advice though, thank you once again.
