Hey guys!
Time for another update, albeit a small one. I did hint that I had been working on some ideas for the cables. I have used Teleios sleeving in Mid blue and Yellow and had a play about with some distressing ideas.
I have used a solution of strong coffee to stain the sleeving. First outcome was very successful. The coffee/ heat made some of the dye in the plastic material to leach out and the overall colour of the sleeving was dulled down, perfect! I have also burnt some of the sleeving away using a jet lighter and used some dye, ink and sharpie pen to mark some of the spots and burns to add some texture. Clear shrink is a nice idea as I can put some coffee underneath it before shrinking, for even more gnar.
The photos were quickly snapped with my Note 4 so the quality isn't great!
On a side note, I have started to spray the panels and case with laquer to protect and ensure the weathering done so far will stay put!
Thanks for looking
Thanks for looking
