Picture quality would be no where in the same league though
Exactly. Not to mention comparing CRT gaming motion versus projector's is like comparing a Ferrari vs an Austin Allegro.
With the amount of money and resources you have, I'd have opted for multiple projectors instead of those bulky CRTs.
That's looking great - subscribed! btw, how did you manage to get 3 FW900s?! I've got the one at the moment and had to scour ebay for ages to find it.
Out of interest, have you ever thought about a multiple projector setup?
vega you are one crazy dude fella
i thought i was bad at dropping money in to computer projects but you my friend make me look like trailer trash in those stakes.
are you married? what does the wife say because mine moans at me all the time about what i spend.... anyway i for one love what you do, you are an innovator for sure and your projects are always tip top so keep it up but one question? are you selling the parts you replace because the way you spend money it wouldnt surprise me if your giving them away. buying 4 x 580 classified just till keplar comes out....OMFG you are crazy or seriously loaded
I have had many problems with EDID info in the past.
The only way I ever got around it was using Powerstrip and forcing custom resolutions with very very detailed tweaks.
I'm not sure if you can force custom timings and get your surround working but it's worth a try?
Vega,
Having a look it seems the BNC connection is a one way connection, whereas VGA is a two-way hence getting the EDID back.
Found this link http://msdn.microsoft.com/en-us/windows/hardware/gg487330 deals with overriding the EDID info via an INF file, now I know you said you looked about masking it so not sure if you have tried this yet.
Either way hope it is of some help
Kimbie
Looking good![]()
Just a point on the Asrock extreme 9. i have a Asrock Z68 Extreme7, what a big PAIN for eyefinity setups and multi gpu's i went to hell and back trying to get the thing running smooth with more than 1 card, 3x 6970's 2x 6990's 2x 7970's nothing would get the thing running with no mouse to screen lag or just poor perfomance, unless i used ether 1 screen or eyefinity with 1 card. The only thing i could put this down to was the NF200 chip, but as this is made by nvidia i think! It probably works with multi nvidia cards and surround.. Just something to keep in mind if you have any problems![]()
Above idea is fail... unless you dont like overclocking!
This project is win though!
