- 7 Feb 2010
Gotta echo Sonnys recommendation - skipping for cardio is a blast, just a heads up though -- if you haven't skipped before dont get discouraged if you are a spaz when starting, the coordination comes fast.
The weights will only work if they're difficult, you're body will only be forced to adapt if the reps you aim for are a serious struggle. 15 reps is fairly arbitrary anyway, 10-12 would be fine too.Could someone clarify this - If I'm doing weights and I step up the weight but really struggling with pushing out 15 reps what am I supposed to do? Just do as many as I can and hope I improve as I go on?
That would be when you need to decide whether more weight would actually be worth it. Considering that when squatting and deadlifting you could probably do 40kg with a proper bar now, and with good training hit 100kg on both within a year, are cheap DB weights a wise investment? Unfortunately, the exercises where you'd use more weight are the ones that are better for fat loss (and everything else...).
It depends. For the time being if you can get yourself gasping for air with what you've got then great. I really don't want to discourage you from doing weights completely, maybe look into doing complexes. For these I use as little as 30-40kg (not a willy waving statement, but compared to what I normally use this is small) and I'm completely destroyed by the end of it.
Read here: http://www.t-nation.com/free_online...cardio_four_complexes_for_a_shredded_physique
I looked at those you linked but I'm 5ft 6 and 190lbs so obese. I don't think I'd have a chance of doing those until my fitness level increases.
I just don't see why it'd be a bad idea to get heavier weights for my dumbells.
edit :
How would this be?
http://www.amazon.co.uk/Purefitness...CE/ref=sr_1_28?ie=UTF8&qid=1324340279&sr=8-28
tbh, i wouldnt go near that stuff
http://www.fitness-superstore.co.uk...grip_olympic_weight_set_7ft_bar_/12593_p.html
that is the bare minimum i can suggest tbh, it will hold its value and will last forever unlike "vinyl" which could only last you a short while.
you will also need matting another £60-100 easy
then a decent bench another £150-200 easy
join a gym, stop looking for a cheap option, cheap options are cheap for a reason.
ebay and 2nd hand from gumtree is worth a shout for olympic gear, but seriously a home gym will only be as good as how much money you throw at it.
With an attitude like that I can't really help you.I looked at those you linked but I'm 5ft 6 and 190lbs so obese. I don't think I'd have a chance of doing those until my fitness level increases.
