150W at 95% efficient create more heat than a kettle at full chat, and laptop cooling is being referenced!
The motors when driving actually shuffle way more energy around (in both directions), active cooling really means you have to arbitrate between cabin and powertrain cooling for the first time in a car as both need air conditioning systems that can provide fluid lower than the air outside.
It was to highlight how until we needed to overcome the issue of the heatsink no one tried to find a better way in regards being able to distribute that heat, why because it wasnt a limiting factor until it was. Then someone put the effort into using that great handy piece of spread out metal.
I mean imagine if your trying to cool something and conveniently the main structure was made of ... metal! Its the sort of thing that comes over time with iterations and efficiency upgrades.
Why have we stuck with active cooling in desktops when we could in effect achieve passive cooling, Its simple price, because its completely possible, but it costs more.
https://silentpc.com/fanless-pcs
Why does every piece of wiring in a current ICE car not need to match the battery cables, they are all connected to the same point eventually.
Oh thats right because you only need the cable to be able to support the current it would draw.
Lets say for simplicity sake (its not I agree but lets keep it simple) you have 2 battery packs one front one rear, they operate independently both driving a pair of wheels. At the charge point you split the feed and send upto 75kwh to each.
Each pack (now half the size of a single one mounted at the rear) is wired to cope with demand and charging for that battery. Obviously you rapidly reach a point of ability to supply the correct voltage and current so you couldnt do this say 2400 times, but its hardly impossible to imagine this 2 way split is it? There would be a point somewhere where all the hardware would be highly inefficient in distributing.
Ok sure if you think by distribute more I mean putting cells literally scattered across the car then that wouldn't work but I dont. I cannot imagine really (unless there is some massive advance in battery tech) of the most logical place remaining the main floor chassis, for all the reasons we know, prevent crushing, minimising cabling, keeping cabling away from riskier areas etc
