Its awfully tempting to get the DWF version right now with the 10% off plus 7% cashback available on topcashback...
works out around £788?
Using code DAILYMAIL8MON
Tempting as I could get another £100 off using AMEX reward, making it £672.
The cashback would work ontop of that right? There's nothing in the terms and conditions on topcashback deal that says otherwise?
What’s stopping you?Its awfully tempting to get the DWF version right now with the 10% off plus 7% cashback available on topcashback...
it'll do that every 4 hours of use unless you disable it within the Monitor settingsThat pixel refresh warning message is pretty annoying. Even after pressing it and the monitor does its thing. Switch the monitor back on and the warning is pinging up again.
For sure its not every 4 hours of use. For example I have dinner so I press the power button to switch it off. The pixel refresh comes on so I do it. Finish dinner and switch monitor back on and the frigging warning is the first thing I see. Also when I first start my PC for the first time when I get home from work it comes on. Haven't even used the monitor yet and its asking me to do a pixel refreshit'll do that every 4 hours of use unless you disable it within the Monitor settings
Maybe switching off the monitor prevents it from running the refresh and then announces that you need to run it when you turn it back on?For sure its not every 4 hours of use. For example I have dinner so I press the power button to switch it off. The pixel refresh comes on so I do it. Finish dinner and switch monitor back on and the frigging warning is the first thing I see. Also when I first start my PC for the first time when I get home from work it comes on. Haven't even used the monitor yet and its asking me to do a pixel refresh
Yup 100% its doing the refresh. The monitor stays off after the refresh and only switches on when you press the power button. Never used the monitor buttons so much before. Hope they are hard wearing lolMaybe switching off the monitor prevents it from running the refresh and then announces that you need to run it when you turn it back on?
To know its doing the refresh the power button turns green, leaving it on standby will run the refresh automatically
I never need to use the power button, it does the refresh in standby mode then the next time I turn the pc on the monitor just turns on as normalYup 100% its doing the refresh. The monitor stays off after the refresh and only switches on when you press the power button. Never used the monitor buttons so much before. Hope they are hard wearing lol
Hold the power button in for a few seconds and it’ll give you the option to refresh and it’ll turn off afterwards.That pixel refresh warning message is pretty annoying. Even after pressing it and the monitor does its thing. Switch the monitor back on and the warning is pinging up again.
Crack on and buy it![]()
The monitor is amazing, received it today, but regrettably it’s just a bit too big for me. I wish I didn’t have such stupid vestibular problems because this is pretty much peak monitor. The colours are insane. And the price was excellent for what you get. Argh.
Might have to try one of the 27” OLED’s instead as that’s about as big as I can tolerate on a desk.
