DW is a great monitor no doubt but I have to agree with Hardware Unboxed's video from June, Given the choice the DWF especially with the latest firmware is a no brainer compared to the DW as the only real world difference now is a G-Sync module and 10Hz while being £200 more expensive. If it was the same price yeah sure but £200 for 10Hz and a G-sync module that you'll never be able to tell the difference compared to the latest implementation of VRR ? No thanks, I'd rather pocket the £200
The DW was the better choice for several months and that's not uncommon. AMD allows manufacturers to launch Freesync and VRR monitors in a completely broken state where as Nvidia refuses to certify monitors that don't work, that's probably because Nvidia doesn't like firmware updates so the monitor need to be as trouble free as possible.
that's just a side effect of the two different business models. Freesync monitors will often be broken at release and need several months of firmware updates to get fixed, that's why they are cheaper but if you wait a while and buy them later then they work just fine like the dwf does now on.
Like Nvidia says, it just works and the more you buy the more you save - and that applies to monitors and applied to the DW vs the DWF, the DW just worked, period and you paid more but saved time and hassle.
