- 13 Jun 2011
Off the shelf mate. Didnt have time to get one made.
My system has finally gone stable (ish) on my reef tank except phosphates which are a battle which is raging on but im cutting back on my removal methods and it isnt creeping in as badly.
Adding a correct wavemaker actually seemed to help a lot on winning this war. I went from 2 jabao sw4s to one Vortech mp10 and the difference is unreal. I don't get build up of junk in my tank now, my skimmers producing much thicker junk and its very dark right now best iv ever seen it working. And the algae on sand has receeded possibly again due to flow
My current battle in my anemone hes not sure were he wants to sit with a new wavemaker
Make sure you put the foam cover on the mp10 whilst its moving about. Ive lost
Many nem “babys” to my mp10s but my tanks big enough to cope and i call it natural selection.
A big nem going thru a p/h could be enough to nuke a tank
Argh, just when everything was nice and stable...
Water went cloudy over the last week and all my softies have really shrunk, my candy canes have gone really gaunt and the flesh is stripping off my plating montipora, my water is all fine*:
1.027 sg
9dkh
8.0 ph
450 calc
1500* mg
Phos and nitrates 0
I'm guessing the mg is the issue, I dosed it last week as it was a little low, but only enough to increase it by ~15ppm.
Other than water changes, is it just a case of crossing my fingers and waiting?
I meant to ask before mate but where from. Im looking at a bigger one myself but not sure on what maximum size to go for
Anyone have any ideas what other decent filter media I can add to existing marine tank? I currently use filter sponge and filter floss pad's. Would adding seachem purigen and chemi pure blue be ok? Thanks
Thanks it's ok as it's a fish only tank for now. Would it be ok if I have like purigen in another chamber and my existing mechanical filtration that is next to it?? ThanksNo need to add purigen with chemi pure blue as its already got it in, just be carefull with chemi blue or purigen on its own if you have sps corals as it can strip the, rowa phos and a decent carbon in a reactor if you have room.
Yeah just get some flow through the bag really does polish the water and takes out the yellow tint.Thanks it's ok as it's a fish only tank for now. Would it be ok if I have like purigen in another chamber and my existing mechanical filtration that is next to it?? Thanks
Nice, cheers mate ordered it.Yeah just get some flow through the bag really does polish the water and takes out the yellow tint.
Does any1 have any experience with rose bubble tip anemone, I will be collecting two small ones in two days. Cheers
Wow that is nice mate, is there any need for dosage for alkalinity,calcium magnesium and all that?Yeah i have 3/4 in my tank. They were doing fantastic up untill i moved house but they are still sulking a month later.
They are very fickle for want of a better word. And sulk if everything isnt perfect for them, also prone to taking a trip thru your powerheads
