Checked your pressures? Too high and you would significantly reduce the tyre contact patch
Have checked them a couple of times - I’ve got TPM on the Boxster and they’re all showing as 33, which is the recommended pressure.
Having a very quick and dirty look online most show having split tyre pressures front and rear? Most places seem to recommend 29 or 30 front and 36 Rear?Have checked them a couple of times - I’ve got TPM on the Boxster and they’re all showing as 33, which is the recommended pressure.
Looking at when I've had things changed, first set of MPS4S fronts lasted about 20k, second set of fronts have been on for 10k and have 4.5mm left.the mps4s has slightly better wear rates than the f1a5(6) and a league better than the csc6
how many miles did you get out of the rears? i got approx 28k out of my set
and running mismatched tyres!Ordered the Michelins this morning to be fitted Thursday, they didn't have the Contis in stock in my size so saved the dilemma!
Meh they wouldn't be mismatched long, and running different axles not exactly going to cause any issues. But would be annoying to seeand running mismatched tyres!
(my next set would probably be the F1A6 when i next change out though...i think it has the best blend of performance/wear/reliability imo)
Just got 2 asymmetric 6s today from national tyres/halfords. £173 all in using there price match 225 40 18.Goodyear F1A6 for BMWs
19 inch fronts (225/40/19) x2
£288 inc fitting with code LEAP20
New 225 40 19 Goodyear Eagle F1 Asymmetric 6 225/40R19 93Y XL Summer | eBay
225/40R19 93Y XL. Features and Benefits Improved dry performance Electric Vehicle ready Improved wet braking. Fitting is available on select tyres for fitters in your local area. Select the fitting option (near buy button) and proceed to the fitting page by adding to basket or using buy it now...www.ebay.co.uk
19 inch rears (255/35/19) x2
£255 inc fitting with code LEAP20
255 35 19 96Y XL - Goodyear Eagle F1 Asymmetric 6 - Tyre Only x1 | eBay
Goodyear Eagle F1 Asymmetric 6 255/35 R19. This is developed as a High Performance Tyre.<br><br> Speed rating of Y and a load rating of 96.<br>Fuel efficiency (A-E): C<br>Wet grip (A-E): A<br>External Rolling Noise (dB; class): 70 Awww.ebay.co.uk
LEAP20 can be used three times, so total = £543
If the tyres are the same across an axle and are good tyres on each axle I don't see the problem to be honest, I always replace tyres in pairs and don't usually bother trying to match them up if a better option is available.
Its not like you will really notice unless you scrutinise your own sidewalls either. Unless you plan on white lettering them?
You'll spend more time and energy than what the tyre is worth.Good morning all!
So I was on my way home from work Tuesday night and hit the mother of all pot holes heading north on the A1M motorway half a mile from the Stevenage turn off thought I'd totalled my alloy but just got left with a bulge on the tyre
This is on my 530D with Michelin 245/35 r20 95y runflat pilot sport 3 (No clue when it comes to tyres) hence me posting here for guidance?
I've heard I can claim for it if I have photographic evidence, is that right?
Many thanks in advance
Good morning all!
