Guess I should do something about mine then![]()
Amen to that !
Get Prime version P95V254
thanx for the answer going to order in the next few days thenI'd recommend a G0 even if someone wasnt OC'ing at all, just for the lower power requirements and cooler temps
Hi Guys,
Been playing around with getting temps right for my Q6600 I am using an Abit IP35 Pro, and a Thermalright SI-128 in an Antec Sonata Case. I originally had a push pull with a 120mm pushing from the front over my Hard disks and another 120mm Pulling out back plus a 120mm on the HS itself.
At 3006ghz 334 x 9 I was getting 70/75 under load that was after 1hour with 4 Primes running
I then changed the back 120mm to a push so all of my fans are pushing this has reduced my temps to 61 under load is that still too high ?
I put the AS5 on the CPU as decribed on the AS site that is one long line across the CPU and then rotated the HS.
Can anyone suggest any ways of getting my temps down ?
Cheers
Shorty
How much does it matter if Prime does show an error? The pc seem fine but when I ran prime it brought up an error on one of the cores after 9mins? I have the CPU a 3.2Ghz and the temps never go above 65c. Thanks for any help
Expect around 3ghz![]()
Nope just dial in the clock at stock volts, should be fine.Darn im sorry but im new to the intel platform so erm is there anything i need to disable in bios for that type of overclock?
