- 23 May 2006
- Blythe
soles are OK they just need more maintainence than other better brakes but you'll get along fine on them for a while
Frame: A1 Premium Aluminum, disc only, double butted ORE DT, externally relieved head tube, reinforced disc mount, forged dropouts w/ replaceable 98954020 hanger
Forks: RST Gilla Plus T7, 100mm, Cro-Mo steerer, 30mm stanchions, coil MCU w/ preload adjust
Gear shifters:Shimano Alivio M-410 SL Rapid Fire
Front mech: Shimano Acera M-330
Rear mech: Shimano Acera
Crankset: Truvativ ISO Flow 3.0 for Power Spline, replaceable rings
Cassette: Shimano MFHG-40, 8-speed, 11-32t
Rims: Specialized/Alex HRD 26, double wall disc
Hubs F: Specialized Hi Lo disc, 36h, CNC flange and disc mount, QR. R:Shimano M-475 Disc, cassette, 36h
Tyres: Specialized Resolution, 26x2.1", 30TPI, wire bead
Saddle: Specialized Body Geometry, ATB
Seat post: Alloy micro adjust
Stem: Specialized 3D forged alloy, two bolt, 25.4mm, 10 degree rise
Handlebar: Alloy 25.4mm, 38mm rise, 620mm wide, 8 degree back, 6 degree up sweep, 3.2mm thick
Grips: Specialized Enduro, dual density Kraton
Brakes: Hayes Sole hydraulic w/ 6" v-cut rotors
Thats the spec, worth it for £330? read reviews it is a heavy bike which actually may be on my side slightly more as im using it for fitness/burning calories/body fat etc. Probly both on road and some off road use like on trails etc.
I would want better than that for the money
Well I went for an XT front mech and the new 2008 SL M770.
Should give me nice smooth gearchanges.
I might look into that, what are the differences over standard.get some flying snake gear cables. they will improve your shifting no end.
ALLI what kind of bike is that? Custom built ?
Ah, out of my budget then
Im thinking of around £700 - £800 for the whole bike![]()
Got a few things to buy though first. Also a car to buy and insure
