Big Bike Thread
Status
Not open for further replies.
Frame: A1 Premium Aluminum, disc only, double butted ORE DT, externally relieved head tube, reinforced disc mount, forged dropouts w/ replaceable 98954020 hanger
Forks: RST Gilla Plus T7, 100mm, Cro-Mo steerer, 30mm stanchions, coil MCU w/ preload adjust
Gear shifters:Shimano Alivio M-410 SL Rapid Fire
Front mech: Shimano Acera M-330
Rear mech: Shimano Acera
Crankset: Truvativ ISO Flow 3.0 for Power Spline, replaceable rings
Cassette: Shimano MFHG-40, 8-speed, 11-32t
Rims: Specialized/Alex HRD 26, double wall disc
Hubs F: Specialized Hi Lo disc, 36h, CNC flange and disc mount, QR. R:Shimano M-475 Disc, cassette, 36h
Tyres: Specialized Resolution, 26x2.1", 30TPI, wire bead
Saddle: Specialized Body Geometry, ATB
Seat post: Alloy micro adjust
Stem: Specialized 3D forged alloy, two bolt, 25.4mm, 10 degree rise
Handlebar: Alloy 25.4mm, 38mm rise, 620mm wide, 8 degree back, 6 degree up sweep, 3.2mm thick
Grips: Specialized Enduro, dual density Kraton
Brakes: Hayes Sole hydraulic w/ 6" v-cut rotors
Thats the spec, worth it for £330? read reviews it is a heavy bike which actually may be on my side slightly more as im using it for fitness/burning calories/body fat etc. Probly both on road and some off road use like on trails etc.
I would want better than that for the money if secondhand that is.
All these suggestions for a new bike, makes me want to get a new one. Would;nt be after christmas though. Hopefully I would have picked a decent spec'd one by then :p
Oh god so if you saw my post on hating doere hubs...i had the lovely task of replacing the freehub.
First time i have did it and it turned out ok,all is working fine again. I would rather do it on a hub with sealed cartridge bearings as getting all the bearing back in correctly and getting it done up tight was a pain in the arse.
Help
i am riding a Trek fuel ex 9.5 and have realised that the riser bars are making my wrists sore when i stand and climb, they put your wrists at funny angles
They are Bontrager with a 12 degree stem any suggestions for a higher lifting stem and maybe revert to straight bars to avoid sore wrists or will this dissipate with more riding?
Would have to be a hardtail me thinks. Dont fly down hills that often :p
Im thinking it would be just after christmas when I get a new bike. The Dawes Oxide 05' Ive got now would have to be replaced with something a bit better ;) Got a few things to buy though first. Also a car to buy and insure :p
Status
