Post your hard drive benchmarks!
Any file smaller than the stripe is NOT RAID0'ed so to speak. i.e. it will be placed on one or the other disks.
I would highly recommend smaller stripes unless you are doing video editing. The O/S is the main stay, and for this I would recommend 32KB. 16KB requires too much defragging all the time. 32KB is a happy medium between a good OS speed increase and good gaming performance. I would not suggest running 128KB as the OS just wouldn't benefit. Most files for an OS are tiny - .dll's etc and would highly likely be below 128KB. Most are around 20KB or so. This is why I suggest 32KB. Games will still load quicker, but the large cache files may not benefit as much as if it was a large stripe. The question is, how much of playing a game is actually the map loading, and how much is the reading of DirectX files etc and other files to bring everything into motion?
Just my 2p anyway.
I opted for 128KB for my 1 TB Raid 0 setup.
This will be filled with mini DV files that are huge and will help with video editing.
I have also installed my games on this array.
But just keep windows on a single 150 GIG raptor with two partitions.
One for XP and the other for vista (if I ever decide to use it!)
Just my 2p anyway.
Perhaps 64KB would be a nice happy medium then?
Here's mine. Not too shabby for a silent setup...
^^ Very nice, is that using that hybrid option?
Again here me trying to test a software raid, this time with the small test Nero has.
First three drives are partitions all on a samsung 160gb and F:\ is a 3x40gb 7200.7 dynamic drive
Pretty good for a single drive :)
<Fluff> Not arrf! </Fluff>
I've seen that drive produce slightly quicker benchmarks for other folk (maybe 5% only) but that's still comfortably quicker than any other single drive in this thread I think. I can't justify replacing my current stack of 250s with these but I can definitely see some 7200.11s coming my way.
Quite impressed with the latest 250GB HD's
When are the 7200.11 coming out?
I dont think there will be anything smaller than 500GB coming out for the 7200.11 series.
No idea when they'll be out. There *might* be a 320Gb version but certainly nothing less, the new 250Gb 7200.10 is in effect a .11.
The model number which is quoted on the OCUK site is the single platter model so you'd be entitled to expect to receive that model.
I think the slower benchmark will be because of the fact that I'm using the drive on the ATA150 not 300 and that the rest of my machine is at least 3 years old. Even so it still doesn't make that much of a difference so if you're looking for a larger replacement drive (which I was instead of my 34Gb raptor for my OS) you can't really go wrong.
When I do finally plan on getting a new computer I'll get another one of these and raid 0 them, then look into the 7200.11s for some larger storage :)
Oh, and thanks rpstewart for pointing me in the direction of this :) Following your recommendation I got the drive (using the OCUK of course ;) ) and I've now got the long job of installing/updating XP and installing everything back on :)
Two WD5000AAKS striped.
Thats using the standard Vista/Nvidia driver.
Im not sure if it is worth installing the latest Nvidia driver.
That's a slightly oddly shaped curve but the numbers look pretty good. I'd be tempted to leave things as they are unless you have any specific problems.
