Post your hard drive benchmarks!
My 150 GIG raptor
Faster than yours!:p
12x 15k sas drives in raid 0 :D
Not works, they have no use for stuff like this :D
Which drives are they, what controller are you using, what size stripe you running, writeback/thru, caching, favourite chocolate? :p You running off expanders?
With MTBFs of around 1.4 million hours (seagate) the 12 would still last an average of 13 years - should be fine :D
Noob question.
It would be faster having my games on the raptor over the Raid 0?
Due to faster access times?
Should get quicker level loads - usually work putting windows/swap on the Raptor for the fast access time and your big data transfer stuff (games!) on the Raid 0 - then add more drives to get more speed :D
Can someone give me a little clue please! :(
Im gonna be setting this up later.
Since you're going in fresh I'd have a play around before you install anything - try it at different sizes to find the best for your rig - I found little difference with mine, but 64k was a dog (half the speed of the others for some reason) - well worth the extra 15 minutes it takes to set/bench each one.
Sometimes the smaller stripe size can have a negative effect.
It all depends on what file sizes will be written to disk.
For editing video a larger stripe is beneficial.
Well im just going to be using it for loading games, running the os/apps things like that. Wont be doing much video work or stuff like that.
So you reckon 128k?
So you reckon 128k?
seems to be the one of choice for many.
I personally CBA having Raid 0 for windows.
I find a single 150 GIG raptor is fine.
Games and other stuff etc.. on a 1 TB raid Raid 0 array
i reckon 64k will be a good stripe size Scoobie Dave, 128k is too high if your not dealing with large files.
Any file smaller than the stripe is NOT RAID0'ed so to speak. i.e. it will be placed on one or the other disks.
I would highly recommend smaller stripes unless you are doing video editing. The O/S is the main stay, and for this I would recommend 32KB. 16KB requires too much defragging all the time. 32KB is a happy medium between a good OS speed increase and good gaming performance. I would not suggest running 128KB as the OS just wouldn't benefit. Most files for an OS are tiny - .dll's etc and would highly likely be below 128KB. Most are around 20KB or so. This is why I suggest 32KB. Games will still load quicker, but the large cache files may not benefit as much as if it was a large stripe. The question is, how much of playing a game is actually the map loading, and how much is the reading of DirectX files etc and other files to bring everything into motion?
Just my 2p anyway.
