I just tried to OC my Q6600.I tried at 3Ghz 1.3050Vcore,and the PWM went up to 80C and the board started beeping!!Is this normal?PWM idle temps are 55C with everything at stock.Can it be a faulty board?
How are you cooling CPU & system?
A quad draws twice as much amperage as a dual so you will get higher PWM temps particularly when overclocked.
55C idle seems high though.
80c ive had 90. were you priming it when it went up 2 80?. we have the same case all i have done is add a 80mm an above it. wedged against the psu and the 120mm exhaust fan. my temps are 70c when priming now.
i think your problem is the pwm heatsink is not flat on the mosfets.im at 3.6 idling at 45(with fan) but you are at stock with stock volts. seems high. i checked the flatness on my heatsinks before i started working on the board. they seemes ok. here is a link for you
http://forums.anandtech.com/messageview.aspx?catid=29&threadid=2088653
so the PWM doesn't get the air flow that it normally would from an aircooled cpu & hsf.Cpu is watercooled.
You need to improve airflow over that section of the board (or get a block for the mosfets too).
The PWM section is in the top left hand corner of the mobo between the socket & the IO plane.There are 3 heatsinks in this board,I think that the PWM one is the middle one,right?How can I improve airflow?
I do, but I can't give you a link, they're a competitor. Best I can do is give you a part number to google. UH23ADo you know where you can get the 1Kohm resister from to do this mod? The vdroop is terrible on this board with quad.
First thing I did was bolt down the PWM heatsink, do away with the plastic pins. They don't apply enough pressure.i think your problem is the pwm heatsink is not flat on the mosfets.
Yeah, I have 3 40x10mm fans all controlled by the board, assisting the cooling. I wouldn't worry to much what the sensor is reading, as its very close to the hot areas. I'd concentrate on getting some air over the hottest components. There are two rows of capacitors that get impressively hot. The one's tucked in behind the PWM heatsink get no air flow at all, be careful they're hot enough to burn, ouch.You mean a small fan,like the ones that come with some boards chipsets?Because I cant understand how I could place a bigger fan.Prime running for 43 minutes now,PWM is at 82C and cpu temps at 52 52 49 46,what do you think?
Can you get a custom MOSFET cooler for this board? I heard the HR-09's dont fit (U or S type).
I dont suppose you could tell me which bits you wire up to where?
Yes the whole assembly has to come off, not hard. Just use a pair of thin nose pliers and have some replacement TIM, Céramique is the best bet for this job.A fan will do the job,right?Im not very good at modding and these coolers are a bit pricey.If I want to remove the PWM heatsink to place it correctly(if it isnt already),will I have to remove the whole heatsinks/heatpipes thingy?Is it difficult?
.What temps do you guys get?I'm pretty sure that molex connection is only when running Crossfire.a quick and simple question:
is the 4-pin Molex connector between PCI-e and PCI (in the most unusual place) needed for single 8800GTS configuration?
it messes up my carefully planned cable management
