Been trying to set up Raid0 with my Abit pro but with big headaches to go with it.
Unless im doing something completely wrong I might have trouble with one of my Raptors.
This is what I have been doing from the start. . . First I would go into the bios and enable the Raid function then reboot. Then I would go into the Raid setup, select the disks (I only have the Raptors connected to make things simple) go through the options for creating the array which goes smoothly. Then I let it boot from the Vista64 dvd til you get to the section where you select the hard drives, and the raptor array is there ready and waiting. I click the more options tab (that gives you options for formatting/load driver etc). This is where I'm a little bit confused as the raid array is listed as 'Unallocated space' so to change that I have to press the 'new' tab and once that is done you can format the drive if you want also (would not give me the option for formatting before as it was grayed out). Whether or not I have to do this I'm unsure, so if someone can clarify this that would help.
Anyway after I have done that I then click next when it tries to install, and this is where it goes funny. Its quite random on where it stops, it always does that small bit or writing to the hard drive, then it goes on to the next step where it's expanding, and you get the (12% . . . etc progress thing) but I have never gotten past this stage. It will either get so far and just come up with a message saying that the 'drive was lost' or something like that, or I have had lock ups and sometimes even a blue screen.
As far as I'm aware doing the above should get me going, unless I'm missing something here.
I even installed Vista on one of my 7200.10 Barracudas last night, and it worked fine first time.
This is really frustrating. What I am doing at the moment is testing each Raptor, I am writing zeros to both drives so they are completely wiped, and I will run the other diagnostics to see if the drives are ok. Then if they both pass the tests I will install Vista on each Raptor just so I know they definitely work. If I get this far with the Raptors then I really dont know, but my gut feeling is one of the drives is failing. Only time will tell. . .
Anyone else had any experiences like this?
