gonna aim for 3.4ghz anyway, think it was around 75c but not stable, so probably would be 80c before I can get it stable
Thats just to hot mate
what "latest game" are you playing?This quad is amazing. I really didn't think it would make too much difference to my games but I was wrong, it's a beast even at just 3.2Ghz!
I play at 1920 x 1200 on a 320 MB 8800. I thought it was a lack of memory on the graphics card causing some stutters in an intensive part of the latest games, but it was my old AMD dual core. Everything flies along now it's awesome.
And I'm future proofed aswell for when the games become multi core capable. Awesome.![]()
i get a lot of shutters in World in Conflict with unoverclocked BFG 8800GTS 320MB OC1, and overclocking the Q6600 doesn't make a difference. only when i overclock the 8800GTS to 650/1000 where it made 4-5 FPS difference for minimum framerate (was 12-13 now 17-18)
and what voltages are you running at 3.2Ghz? i got BSOD when at 3.2Ghz, 1.395v in the Bios, and 1.34 under load after Vdroop
echo...
How about with 1.4v running through it?
When I tried 400x9 I put the voltage up to 1.4125v anyway![]()
you must have one of the best batches of Q6600The games i'm playing are bioshock, medal of honour airborne, (both UT3 engine and uses 4 cores!!), stalker, world in conflict, etc. All of these were not smooth with the AMD but now run great with the quad core. All games listed are now smoth at native res mostly on max or nearly max settings (but no AA). World in conflict I think is to only game that will still stutter on occasion!!
I'm running 1.350 volts in bios (1.250 volts after vdroop and vdrop under load or 1.296 idle). Orthos stable under full load.
Not sure if i'm going to bother overclocking more unless I need to in the future.
only 1.35 required for 3.2Ghz!
i had to turn off soft shadow, AA, a few water reflection options and lower resolution to 1280x800 to have above minimum of 15 for in-game benchmarkyou must have one of the best batches of Q6600only 1.35 required for 3.2Ghz!
Bioshock, Medal of Honuor Airborne are very smooth. but STALKER gets a bit of stutter here and there which is expected since it doesn't use all 4 cores. but i can't get World in Conflict to work smoothly with everything maxed outi had to turn off soft shadow, AA, a few water reflection options and lower resolution to 1280x800 to have above minimum of 15 for in-game benchmark
Temps look good, great clock for air.
