Official Crysis Demo thread
3 Mar 2003
Canterbury
con_restricted=0
e_detail_materials_view_dist_xy 4096
e_detail_materials_view_dist_z 256
e_vegetation_sprites_distance_ratio 2
e_view_dist_ratio_vegetation 50
e_lod_ratio 8
e_max_entity_lights 20
r_EnvTexUpdateInterval 0.025
r_beams 1
r_beamsDistfactor 0.01
r_beamsmaxslices 300
e_vegetation_bending 1
r_HDRlevel .75
r_useedgeAA 2
r_ssao_quality 4
r_ssao_amount 2
r_ssao_radius 15
r_TerrainAO_FadeDist 0
r_SSAO_darkening 0.15
r_eyeadaptationfactor 0.25
r_HDRBrightThreshold 4
Severe framerate hit for me and also way too dark in some areas. Using the settings used in the popular video I get much smoother framerate.
3 Mar 2003
Canterbury
Annnnnnd what would they be sir?
HDR dynamic power factor 1.71418
Sky brightening (terrain occlusion) 0.842513
SSAO amount multiplier 2.5
Sun color 235 / 190/ 122
Sun color multiplier 16
Sun specular multiplier 1.88571
Sky color 100,139,241
Sky color multiplier 0.5
Fog color 151 /194 / 233
Fog color multiplier 8.23017
Volumetric fog: Global density 0.2
Atmosphere height 29791.2
Volumetric fog: Density offset 0.01
Sky light: Sun intensity 255,255,255
Sky light: Sun intensity multiplier 0.00270176
Sky light: Mie scattering 571391
Sky light: Rayleigh scattering 0.902763
Sky light: Sun anisotropy factor 0.999464
Sky light: Wavelength R 734.263
Sky light: Wavelength (G) 602.222
Sky light: Wavelength (B) 523.79
Sun shafts visibility 1
Sun rays visibility 10
Sun rays attenuation 0.5
Color: saturation 1
Color: contrast 1
Color: brightness 1
Levels: gamma 1
EyeAdaption: Clamp 4
Dof: focus range 1000
Dof: blur amount 0
3 Aug 2003
UK
To: Mr***********
(andy******@hotmail.com)
Your order for Crysis placed on the 26/02/07 has been posted.
Please note *******.COM will show on your statement.
Please allow 3-5 days delivery.
ABOUT BLOODY TIME
26 May 2007
hi there does any1 know how i can
change the resolution in the game if its not in the game menu.
thx again in responce. ;)
C:\Documents and Settings\*your log on name*\My Documents\My Games\Crysis_SP_DEMO
there is a file game.cfg in there ...open it with wordpad
change these lines to read your choice of res
r_Height =
r_Width =
29 May 2007
Play “ultra high” setting with “high” performance in XP
After spending hours of tweaking I found a way to enjoy ultra quality Crysis with playable fps. With the tweaked files, I can get the quality that even better than very high setting but with a very good fps.
My spec is Core 2 3.15GHz, 2GB RAM, a single 8800GTX (630/950), 169.09, Windows XP. I reckon many of you have similar spec and is wondering how to play Crysis in very high with playable fps, in either 1680x1050 or even 1920x1200.
I am running on 1920x1200. With the original “tweaked” very high setting in XP (which is almost identical to vista dx10 very high), I get average 18.42 fps in the GPU benchmark test which is barely unplayable. IMO Crysis runs pretty smooth with 25 fps and that would be most of the ppl aiming for with todays hardware in very high setting. With my tweaked files, I get an average of 23.02 fps, which is very playable to me, and most importantly, the quality is even better than very high (more realistic to me).
Look at the following screenshots for comparison
Screenshot 1
Very high:
Tweaked ultra
Screenshot 2
Very high:
Tweaked ultra
Screenshot 3
Very high:
Tweaked ultra
Screenshot 4
Very high:
Tweaked ultra
Sorry for the bad quality due to the compression, you will find it more beautiful in person and on average I get 6-7 fps more with the tweaked setting. Basically I just make the lighting looks like more dynamic and improve the contrast of bright and dark areas to make it look more realistic, and I turned down some shadow, vegetation and particles to get more fps, you won’t notice the difference anyway, believe me.
Download here
18 Apr 2006
]8-
/snip
Download here
holy smoly, those pics make the game look a 100*better ... damn ill have to install the demo again to try that ... nice work
*** ah im using vista... maybe thats why i dont see a diff*** but thx
