- 17 Oct 2002
Yes, I'm planning on getting an 8GB SDHC for my holiday in January.
You at York uni?
Also, the ones that OCUK have in stock at the moment are only 2gb of memory arent they? How much space does that leave you with for storing files etc? Is it worth waiting for the 4gb ones to come back into stock?
Do the Eee PCs take SDHC, or just the old SD cards?
Does the Eee support WPA2?
My girlfriends dad recieved one for christmas and just wondering whether it supports our exisiting WLAN or if I have to drop it to WPA.
Yes,it does. I've just got mine and configured it to connect to my WPA2 wireless without any problem at all. And the range is (almost) as good as my wireless-N cards.
Does it support it out of the box or do you have to adjust a few settings? If its the latter, is there a guide floating about?
