*Official* Antec P182 Case's,Builds,Modifications & FAQ's
should click off easy enough!
Cheers marcus, couldn't get the pliers in there but tried a mahoosive flathead and it unclicked no problem, feel a bit silly now but anyway job done lol :)
Just got it set up.
Nice one Will! :D
Nice one Will! :D
I done a vid on youtube (because I felt like doing a vid now copying anyone else) , bit low quality coz youtube like to mess with your videos but its better than pics.
http://www.youtube.com/watch?v=vqN-HxwrxyQ
Nice video and review, a little dark though but still excellent build 10/10 M8..:cool:
Thanks :), yes its well dark It was almost just acceptable on my PC but then youtube kills the quality even more, I reading a couple of tutorials and trying to learn how to imprive the quality :).
Hi,
I got some question about how to connect two jack ports from the front panel to SB Audigy ... did any of u did it?
If yes any tips would be very helpfull...
P180 user :)
Well I bought this case used for a nice price and am very pleased.
It's much more professional looking than the Antec 900, of course much quieter, and wire management is great! However, airflow is nothing compared to the Antec 900....I had a passive northbridge heatsink that kept the NB under 39-40c...and now I've already seen it go to 52c. No worries though I'll just strap on a quiet 92mm fan :)
I'd like to get a side window in the future and paint the interior satin black...but I need to save some money for awhile so I just quickly threw it together and it will look like this for awhile.
You guys know what the case looks like with its side on so I'll just show the goodies:
Very nice gurusan! :)
I have been putting a build togther with this case for the past week lol, I like to take my time. Please post up some more P182 pictures of anything interesting.
Well I did find something interesting!
I was pleasantly surprised to find that the cathode toggleswitch fits PERFECTLY inside the funky holes in the top cage!
I have a P182 SE case, going to start building in the next few weeks, would anyone recommend replacing the stock fans with anything else?
I like the idea of adjusting the speeds via the rear panel, is there any that come ready like that or can a standar 120mm fan be modded to make it do this via the antec switches on the rear
Thanks
I am sticking with the three stock Antec Tri-Cool fans provided and see how it goes, I'm in no rush to spend an extra £20-£30 on top of the case cost. I have used the Antec Tri Cools before and they are decent enough, had them set to low and they are fairly quiet but still do their job.
As far as I know its only the Antec Tri-Cools that come with the little adjuster. If you want to take it to the max then consider buying some powerful fans and hooking them up to a fan controller at the front of the case, otherwise just stick with the Tri-Cools and see how you get on.
