Cheers marcus, couldn't get the pliers in there but tried a mahoosive flathead and it unclicked no problem, feel a bit silly now but anyway job done lolshould click off easy enough!
Nice one Will!Just got it set up.
Nice one Will!
Nice video and review, a little dark though but still excellent build 10/10 M8..
Thanks .
I done a vid on youtube (because I felt like doing a vid now copying anyone else) , bit low quality coz youtube like to mess with your videos but its better than pics.
http://www.youtube.com/watch?v=vqN-HxwrxyQ
Just shoehorned a new cooler on my GTX
Erm dunno if your aware or noticed yet but...that memory heatsink 2nd from right has fallen off and not even making contact!
Lol I still can't see what you guys are talking aboutWhat a spot....
I am sticking with the three stock Antec Tri-Cool fans provided and see how it goes, I'm in no rush to spend an extra £20-£30 on top of the case cost. I have used the Antec Tri Cools before and they are decent enough, had them set to low and they are fairly quiet but still do their job.I have a P182 SE case, going to start building in the next few weeks, would anyone recommend replacing the stock fans with anything else?
As far as I know its only the Antec Tri-Cools that come with the little adjuster. If you want to take it to the max then consider buying some powerful fans and hooking them up to a fan controller at the front of the case, otherwise just stick with the Tri-Cools and see how you get on.I like the idea of adjusting the speeds via the rear panel, is there any that come ready like that or can a standar 120mm fan be modded to make it do this via the antec switches on the rear
