So let me get this straight. First DGM was shot to bits.
And second one exhibited bad backlight bleed. I.e. you returned 2 DGMs?
Nice work Sherlock!!
Nice work Sherlock!!![]()
Hmm thats a bit unlucky!
Ok so I have the M240W01 Panel (or whatever the code is).
Its a V3 also.
Is this a bad one?
You tell us. To your eyes, do you think its a good screen?
So, is that backlight bleed?
Also, are you saying that you were watching a movie, then all of a sudden it stopped the movie (all by itself), and went back to the desktop...that is your desktop, right? After which, all by itself, it showed a blank screen which got progressively darker?
If the above is what occurred, I suggest you get a priest to carry out an exorcism.![]()
The monitor seems to have lost its uniformity. I would watch another movie or have another gaming session, to if it clears up. If it doesnt, then you would have to think about getting it replaced.
How long have you had the monitor for? You might still be able to get a refund.
Are we supposed to have vsync on with LCDs?
Looks like I've got the same issue, the screen was nice and black all over for the first day but now the backlight is bleeding through the corners. Will this and the stuck pixels mid screen I'm not impressed. Will give it til tomorrow morning and then its going back.Less than 48 hours. Came in Friday morning.
This issue was certainly not present initially. It seemed to have developed over time, and frankly I dont think this is going to go away as it seems to be a mechanical defect as opposed to an electronic one.
Really miffed tbh :|
Thanks for the advice though sunama, ill give it a bit more time, but if the issue hasnt subsided by tomorrow, I think its safe to say that this is a terminal problem.
I know its not OcUKs fault but it may be worth them dropping this line if they are going to be as hit and miss as this thread is now indicating.
