Well I've requested my order to be changed to the 8400, I plan to "upgrade" to the 3870 X2 when it's out providing it is good. The £50 I saved on the CPU will go with my GTX to buy one of these, so long as they're good ofc.
Decided I would be happy enough with 4-4.2Ghz.
Topitoff results I'm happy with. Hoping he can manage to get 4.2Ghz 12 hrs stable.
Not a lot of pressure then
Currently I have it priming @ 4.23Ghz (470x9); vcore set 1.475, cpu-z reports 1.4v; core temp showing 65 and 69C and it's now been running Blend for 3hrs 8mins.
Edit: now 8hrs 5mins
Hope this helps.
Screenie if it gets to 12hrs.
