im having probem with my 2407WFP-HC...if i rma it, will Dell replace with the 2408WFP?
Yikes, that's 82 ms lag. You should probably run the screens in clone mode though with both at 60 hz or I'm not sure it's a fair test. Might also want to set the 2408 to 1:1 so there's no scaling involved.OK, used virtual stopwatch.
Dell 19inch CRT displays 38 seconds 241 milliseconds
Dell 2408 displays 38 seconds 159 milliseconds
Both screens are set to 1280 because of clone mode and the CRT is running at 85hz.
Do the clocks run up? Because if so, wouldn't the dell be going a lot faster than the other monitor?
.969 for the Dell
.999 for the Viewsonic
Surely this means the Dell is .030 ms faster? =\
I have a feeling im wrong, is anyone able to explain?
Ahhh I seeIt goes up.. it's a stopwatch program..
Example (if I had a CRT attached as well as the ViewSonic display) - If you started the stopwatch program and took a photograph, 70 milliseconds later, of all 3 displays (in the same photo):-
CRT Display: 70 milliseconds
ViewSonic Display: 40 milliseconds
Dell Display: 10 milliseconds
This means that when the stopwatch program has got to 60ms.. the Dell is still showing 0.
It's 3 hundreths slower than the VP2030b, which is 3 hundreths slower than a CRT, so it's actually 6 hundreths, and some of the measurements have been higher than that, around 8, so nearly a tenth. Yes you can percieve it, you can see the mouse pointer doesn't move immediately when you move the mouse. It also means your inputs in FPS games are effectively out of date, behind the game, so it makes hitting things more difficult.Maybe it's just me... but three hundredths of a second doesn't seem like its going to be perceptible with out doing side by sides. Do those people who have this monitor actual perceive it as a problem?
You've got to remember it was a huge deal for online gaming when we got broadband instead of dial-up and pings to the server dropped from about 200 ms to around 30 ms (ping is there and back). You don't want to add another 60-80 ms back onto that because of your screen. So for gamers yes it is an issue.
Of course this screen will still sell by the bucketload and many people (most even) will never notice the problem, especially occasional/casual gamers and non-gamers.
That's what I'd like to know. For those of you who own the monitor, if you're focusing on the cursor and suddenly move the mouse, is there a visible delay before the cursor moves?
