Disable them when overclocking, but you can turn them back on when you've finished.
I have Speedstep and C1E enabled on my E2140 @3.45ghz without any isues.
Hi Cob
Is there any benefit in doing this?
Hi Cob
-iceblade^ : According to your screenie you are running at 2Ghz not 3Ghz!
If u are overclocking and the pc adjusts the voltage/ speeds that u are running could make system unstable. Its just one of those things that universally accepted that it would be best left turned off while overclocking. If its stable with *your* overclock which you already determined (with the settings off), thats a different matter altogether.
I just slipped that tip in as its just one of those basic rudimentary tips that can't hurt to turn off especially while testing a new CPU.
Well there only there to save electricity....so unless your a fan of higher electricity bills then you may aswell switch them back on.I've always turned mine off and left them that way tbh![]()
What volts are you running that at ?Idle it's 39 and under load it's 58/9 is that too warm do we think?
Well my E2140 won't go anything past 400mhz FSB regardless of voltage![]()
3.2 is still a good clock though![]()
that seems high... my '60 idles at arouind 27/30 and capped off in Orthos at 56, usually around 55... @ 1.425V and FSB 333, everything else Auto now... same cooler as you as well
i have limited experience OCing, though, so be warned
why did you apply AS5, though? the cooler comes with some pretty good stuff preapplied...
