- 15 Jan 2004
- Hall
yep.M240UW01 (V0/V4) = MVA panel
M240UW04 (v0/v1) = TN panel
Argh theres some sort of defect on some pixels in the bottom right corner![]()
I was assured again this morning that although the TNs were originally mixed with the PVAs, they now have their own separate order code and all replacements will be PVAs.
Would be interesting to know if those who received TNs as replacements could double check their order and make sure it's not showing up as a TN panel on the order itself ?
My screen had really bad backlight bleeding
And it seems to have faded over time, is this possible, or am I just used to it now...
Well, I finally got an email from them this afternoon saying they were returning my monitor!![]()
A couple of things here - firstly 180 degree viewing angles are impossible since you can't see a flat sceen from a 180 degree angleIf it is the latter, then OcUK need to update the product description to more appropriate viewing angles rather than the stated 180°/180° (H/V).
, also you need to understand that viewing angles don't mean the picture looks the same, they are the angle where the screen is x% (80-90% usually IIRC) darker than from head on. So even my two LCDs which are both S-IPS panels which have the best viewing angles you can get on LCD - they still look quite a lot darker when viewed from a wide angle, pale when viewed from way below, and orange when viewed from above. Even CRTs don't have perfect viewing angles. So you have to be realistic and also to understand what quoted viewing angle mean, but at the same time OcUK shouldn't be quoting 180/180.What are people getting with a direct DGM RMA? I purchased mine a few days after they came out and have a PVA panel, but it now has an entire row of dead pixels. If I send it back to DGM am I going to get a TN back?
That's not really cricket.
In your webnote, did you not attach links to your pics demontrating the problem?
Dear sir/madam,
I ordered the OcUK 24" L2442W Widescreen LCD Monitor, and have arrived at the conclusion that it's a TN panel. However, I ordered this monitor expecting that I would receive a VA panel (as described in the forum and on product page). The model is M240UW04, which matches that of a TN panel. Please refer to this post as further proof: http://forums.overclockers.co.uk/showpost.php?p=11221244&postcount=2513
As you can see, viewing the monitor from a 45 degree vertical angle inverts the colours. This is not what you would expect from a VA panel (in fact, this is what it should look like: http://forums.overclockers.co.uk/showpost.php?p=10552114&postcount=170). This also does not comply with the viewing angles stated on your product page: "Viewing Angle (H/V): 180°/ 180° (VA Panel)".
In the forums (from Gibbo's post: http://forums.overclockers.co.uk/showpost.php?p=11201060&postcount=2451), it was stated that you will replace it at no extra charge (as the fault is on your behalf). Therefore, I am submitting this RMA enquiry so that you may send out another monitor to me and pick up the faulty one.
Regards,
- [Insert full name here]
As posted here by kikifr you don't need to open the monitor to find out what panel is uses but for some reason a lot of people have ignored it.
http://forums.overclockers.co.uk/showthread.php?p=11239965#post11239965
Big Thanks kikifr i now know i have the V0 , Is the ISP command another menu ?
How long do OcUK typically take from receiving an RMA to sending out the replacement ?
