Is it worth getting a 2GB or is 4GB the way to go?
The models?
2G is limited, cant upgrade RAM, slower processor, and the SSD is only 2GB.
4G is the way to go
Trasncend class 6 8gb SDHC card, any good? Can get one for around 18pounds.
I'm thinking about getting one of these, I like the black one!
Could I connect this to my xda orbit II and connect to the internet on the Eee? I have unlimited web usage on my orbit so it would come in handy.
I have a HTC Tornado Windows Mobile 6 Smartphone and I can get on the net with it. Just install ActiveSync and select internet connection sharing on your WM device. Mine is only 2G/GPRS though so a bit on the slow side. 3G would be much better.
good good
I've decided I want a black 4G one, I've just been looking at the different models.
Does anyone know where the black 4G ones (with webcam) are in stock???
Will be tricky to answer that one without mentioning a competitor![]()
Email in trust!![]()
Well, I just picked up a brand new black Eee 4G version with no webcam, for £239.76 delivered!
I've never used linux in my life so that will be coming off. Just need Win XP Pro, Office XP, Firefox, MSN, Activesync and I'll probably grab a bluetooth adapter for it, and I should be sorted.
im hoping to buy one from the MM (when i get access lol)
quick question, i had a whirl on a linux 2g in the purple place and found you had to use the bar to left click!
im used to tapping the touchpad, will the touchpad on the eee let me do this if i put xp on it?
Lee
Lee
