I had this on my faulty monitor! The menu reported it as a v0 but on the actual sticker behind the panel, it was a v4 or something...
Where exactly is the sticker? I had a little look through the vents but couldn't see it...?
Looks like back light problems is the next thing here. My first monitor today is fine but the second is quite a pale grey when ti should be black due to back light leakage. Another RMA tomorrow I'm afraid.
reading through some of the posts....would any of you guys recommend this monitor ?
Very much so, although I got mine just as they started sorting out the issues, according tot he list my panel goes into other manufacturers monitors that are £400+
I have excellent viewing angles, no dead pixels or bleeding.....
Lucky you
One of the Samsung panels?Lucky you
My pc & graphics arent up to running this at full res in-game, could any of you confirm if this can run out of native in games without issues?? Ideally 1680x1050 in counterstrike source^^
Look through the back vent where the DVI/VGA ports are. You should see it there.
will be sitting about 2.5 ft away from the screen. Looking at getting this 24" & a 9600GT or 8800GT
lets hope it on offer soon.
i have one of samsung panels..... it would be good if it worked
Originally Posted by memory View Post
Reading through some of the posts....would any of you guys recommend this monitor ?
^ if you want to wait 1-2months untill you get one that works/not tn then yeh i would!
how do you get the stand off for shipping? overclockers told me could be done but could be tricky and might need two people but didnt go into any specifics, dont want to knacker the stand taking it off or owt
