i decided to get this monitor this week and i have a:
SA-LTM240M2-LO1
is this any good?
cant seem to find any faults with the viewing angles, but i'm no expert.
Thanks Vect0r!
One thing I cannot fully understand is how Digimate would ship monitors with TN panels inside if they announced the specs on their site as VA ones.
http://www.digimate.co.uk/product/L-2442WD.htm
Is it possible to go back directly to Digimate and get the replacement from them or should you do it via OC? After all the three year warranty is with the manufacturer.
Cheers,
Paul
I'l sit and wait for now.. Though the pull of 1920 x 1200 is getting very very great..
Definitely do it through the retailer since Gibbo has already stated in this thread that OcUK will swap all TN panels for VA ones and cover postage. If you go through Digimate you'll have to get into a discussion with them about viewing angles and the screen not meeting specifications, and it's just a less certain outcome.Is it possible to go back directly to Digimate and get the replacement from them or should you do it via OC? After all the three year warranty is with the manufacturer.
Doesnt Ocuk do a dead pixel/VA panel screen check?
Would glady spend £20-30 quid for a quick check and hey its 100%profit for a company like Ocuk.
For the people in the 'know' and been looking around the web, it sounds like Ocuk should follow suit![]()
!! I guess if OCUK could return the ones with even a single dead pixel back to the manufacturer then they probably would offer it. I believe Dell offer the warranty themselves in some cases which is why you often see this offer on their monitors.
Fair points but eye spy with my little eye someones already doing the same screen/possible PVA and dead pixel check and cheaper![]()
? Do they really claim it?Fair points but eye spy with my little eye someones already doing the same screen/possible PVA and dead pixel check and cheaper![]()
