- 17 Aug 2003
- Woburn Sand Dunes
good to see CPW are sending out £100 vouchers. i mean, i did buy mine 2 days before the price cut lol
In all probability won't make the blindest bit of difference. All the bootloader does is boot the OS - the later version is much more restrictive, hence the downgrade.Having just grabbed one from the CPW I was sure I was going to use the Zip Util to do the Unlock, Jailbreak & Activate. However I've been reading that it downgrades the bootloader and that is a bad thing, as there is no ability to upgrade it again?
Didn't need a guide, get ZiPhone for Windows, plug it in so iTunes recognises it, then press "Do It All" in ZiPhone
I suppose that's a guide...
Whats the best Jailbreak guide to use then (Vista machine)?
Just picked up a iPhone![]()
If you have just bought your iPhone, switch it off and connect it to your PC or Mac and hold down the power and home button on your iPhone and release power a second after the screen goes black.
so iTunes has it recognised and wants me to activate it... and i installed ZiPhone V3.0
So just click "Do It All"
Do i need to make sure i have a certain version or anything?
I put it in recovery mode then restoresd it to version 1.14 then i jailbroke it.
Riiight, that's a quicker way I suppose. You not meant to update a jailbroken one I read somewhere?
I have looked everywhere and there is no app for sending files over bluetooth, you had my hopes up!!!!!!!!!!!!!!!!!!
dark_shadow said:Indeed, but waiting to using it as a phone for 4 months aint too bad I spose
Omg can't believe this, i bought the 8gb last wednesday on contract because i thought i will finally get an iphone, i got my bonus at work of 100 quid so took the 8 back to the store and changed it for a 16gb for no real reason.... Now the price of the 8 goes down and i didn't even really need the 16gb.such bad luck on my part... can you guys suggest anything ?
Is there not like a 7 day return policy or something? I would like to think there was. If so, just restore the iPhone and give it back. Get your money and buy the 8Gb again.
, i am now home with a reciept saying -329.99 and +169.99. Really happy at the moment.Latest firmware from Apple - http://appldnld.apple.com.edgesuite...0226.Sw39i/iPhone1,1_1.1.4_4A102_Restore.ipsw
Hold down Shift and click Restore in iTunes and point it to the firmware you just downloaded.
Need to put it in recovery mode (i think), then click shift + restore.Downlaoded this way as it was quicker...
Cant find the option to Restore and point to the firmware tho??
