If you disable the JMicron controller you will lose the IDE drive... it is controlled by the JMicron controller. The only solution is to get a sata optical drive... you will also lose the eSata port.
It'll be fine J.T, my PSU is 4 years old and only has the 4 pin plug but this works fine in my IP35.
Rather than start a new thread thought I would ask a question in here instead, hope that’s ok guys.
I am thinking of getting the IP35 Pro but notice it has a 8 pin power connector at the top but my PSU only has the standard 4 pin one, does this mean it won't work with my PSU?
Also does anyone know if the Asus Silent Square Pro CPU Cooler will fit ok on the IP35 Pro?
Thanks in advance guys.![]()
Have you tried increasing the North Bridge? MCH by 0.1v?Can anyone with Crucial Ballistix tell me what volts they are giving it?
I have 4 x 1Gb and it was happy in my DS3 with 2.1v yet now some of it errors at that voltage in the IP35, I'm hoping the ram hasnt died, we all know Crucial is famous for it.
