This is my first post on this forum, hi all.
I’ve had this 24” DGM L2442WD monitor now for over 5 weeks and I’m very pleased with it. I’ve read almost all of this huge thread, looks like every one are getting different panels looking at all the different code numbers. People are getting a mix of MVA, A-MVA, PVA, TN Film all with there own different strengths and weaknesses. Some bright, some dull.
My panel lottery gave me a SA-LTM240M2-L01 panel which I believe is a S-PVA Samsung one. It’s very bright, a lot brighter then my old 19” Acer LCD. Whites are white. No dead pixels, which is amazing the fact there are over 2.3 million of them
. As some one posted it could have done with a night time setting because in a low light room it can be over bright.
As with everyone here, I taped over the flashing blue LED with a small bit of tape
I think the response rate could have been better on this panel as I do see blurring in games. In fact I can see blurring just moving a web page or window across the screen and you then can then not read the text within it. A more scientific test I did was to use a utility called ‘Pixel Persistence Analyser’, only test I did was the readability test F4. You have to type the words that are scrolling across the screen, the more you get correct the faster the text goes until at one point you can no longer read it. My best score was 8 (higher is better, lower is worst).
I also did some Input lag tests. I see that ‘Gregeff’ had some very good lag test results on his panel, almost no lag, wow. I wish I could say the same about this one. I did 12 photos with my camera phone of my screen next to an old CRT monitor and then did an average of the difference of ‘ms’ between them both. The result a poor of score of 52ms. (ms=1/1000 of a second).
I kind of knew this panel had a lag problem even before doing the tests as I get a small amount of mouse lag. It’s very small but you can feel it ever so slightly when moving the mouse. What you see on screen is what the computer sent 4 frames ago. Which is a bit of a shame as I’m a games player. But for £200 pounds I don’t mind too much. I would have minded if I had bought the £400 24" Dell monitor which has this same problem, same panel in fact. You do get usage to it. Small bad point on a very nice monitor in which I’m very very happy with
SA-LTM240M2-L01
Cruicky
